I just purchased a Dual 1219 which looked to have not been used for quite a while, and seemed stored well, so I was optimistic about it working with little intervention needed. When I tested it at home, just the right channel was working. Reading some advice here, I took off the cartridge and cleaned the contacts - on this one, the head uses the fit and not the pins. I put it back on an tested it, and now there was no sound out of either channel. Realizing the head was not seated correctly, I took it off, reseated, but still no sound. Looking around some more, and thinking about checking continuity, I saw the thread on the mute switch. I cleaned the switch, one of which was not making contact when closed, and checked the continuity from the arm, and it seems like there is not a break anywhere. Connecting it up again, I still do not get any sound, and now the motor does not switch off when the arm is at rest. So, to sum up -
1. No sound right channel, cleaned contacts on head and tone arm
2. Reseated wrong, corrected reseating - no sound from with channel
3. Cleaned mute switch (which included turning plastic gears to look at how worked) - still no sound and now motor does not switch off.
I would mostly love to get the sound back, then figure out the motor, but any help for this turntable noobie would be greatly appreciated.
Thanks!
Thanks!
