churchill127
Member
Hello All,
I am servicing a dual 1219 I found recently, in really pristine condition. disassembled and lubed the speed control, cam, relubed the motor bearings, replaced the stauerpimpel and dearing ring rubber parts. I was fixing up a problem I made myself when I reassembled the cam shaft where the tonearm cueing level was not properly seated in the groove, when a heard a little noise, and a ball bearing fell out onto the table. This ball bearing is larger in size than the ball bearings used for the dearing ring, and I do not know the locations of any other ball bearings in the chassis. Does anyone know what this might be? I am very excited to get this thing finished and spinning vinyl!
Thanks!
Thanks!
