Dual 1219 connection
Jesse Schilk
upload_2022-12-3_16-52-58.png I recently inherited a dual 1219 turntable. I’m trying to set it up but I’m used to using an RCA cable to connect it to my receiver. The female connection on my turntable is fatter than an RCA cable though, and I was wondering if anyone here could help me identify this connection and point me in the right direction on how to connect it to my receiver. Any help would be greatly appreciated!upload_2022-12-3_16-52-58.png
Yes, this is the full photo. I’m trying to find out what kind of cable to use to connect this to my receiver because they appear to be bigger than the standard rca connections
That is the standard RCA connection board. You may just have some narrow connectors on your cable or need to try a different cable. The only issue I’ve found with the Duals is those R and L jacks are a little too close to each other which makes using certain cables difficult or impossible. Giving the jacks a clean may help as well.
I confirm, these are RCA connectors. For connection to the receiver, you need a good cable with low capacitance and low microphonic effect. The cables that came with your Dual turntable were thin and looked cheap but did the job perfectly, use them if you still have them and if they look in good condition. The thick cables and connectors that are fashionable today are not any better, and very often worse as cartridge interconnects. Moreover their bulky connectors are often larger than the spacing between these sockets.
Your sockets are very heavily tarnished and will not make even a half-decent contact. Moreover, wiping them with alcohol or a contact cleaner will not remove such a layer of oxide. The common effective solution is to use metal polish, such as Belgom in France/Belgium or Brasso in Anglo-Saxon countries. You need to deoxidize the outer ground connection and the central signal contact too. Many people use a fiberglass scratch brush, but this cannot reach the central contact and the oxide will quickly come back, so it is mostly useless on the long term. Some operators like SNCF in France prohibit scratching the contacts for this reason, and have specific relay/connector cleaning kits. Another option is to change them for new sockets that can fit that metal part, possibly via a new DIY terminal plate.
This unit will need all contact points cleaned. I restore dual turntables and have never seen such bad oxide.
Metal polish 100% - put it on and leave it for 10 mins. Remove and reapply.
Noxon 7 metal polish (Amazon) and Q tips. Pull off a little cotton and it cleans inside nicely. This connector is also known as a 1/4" RCA connection.
On second thought, those look so bad I would consider replacing them. Remove the leads and drill out the rivet. Replace with new rca connectors and sole a potential intermittent hummm inducing connection .
