Dual 1219 counterweight equivalents?
RS-MN
I picked up a Dual 1219 in rough shape, but it is cleaning up nice, but it's missing a couple parts. One of the main missing pieces is the tonearm counterweight and threaded shaft for it. Do other counterweights/shafts fit this tonearm? (1209? 1229? or others?)
1229 should work for you, have both models and the tonearm is the same although the counterweight for the 1229 has a adjustable "marker" that you would point to 12 o'clock once the arm is balanced (a placeholder of sorts).
Thanks! I'll look for one of those with the shaft. I do see several 1209 counterweights with the shaft. Would that work too?
