Roborobo
Hello! I finally got my 1219 working enough to enjoy it and I really like the sound (and the cool factor, auto play, signal staying off until it cycles correctly, and more). The only issue is that every now and then the motor doesn't switch off immediately after auto return cycles (but with a slight jiggle it clicks off, and this is something I can live with for now), and there's a slight wobble to the platter.
From what I've read, the wobble most likely means I need another platter, but I see that some platters have the spindle attached to the platter and others don't. My spindle is attached to the platter. But I also read the Dual 1219 platters fit interchangeably, which contradicts my assumption.
So, now I'm thinking- is the spindle not supposed to be attached like that? Could my spindle just be stuck and that's why it's got a bit of wobble?
SO, that's my question to you all. Would greatly appreciate any help! Thank you!
Edited for grammar
Edited for grammar
