Hi, I believe the micro switch has been added, not in Service Manual or in my 1219. The arm going into the Factory Power Switch has spring balanced contacts for power on & off. I have made micro adjustment to get it working properly, my 1219 would not shut off. If the contact arm is pushed to the spindle side, that is motor powered 'on'. When the 'off' mechanism is enabled either by the manual 'off' lever or 'end of record' tone arm position, that contact arm will flip to opposite side, 'pwr off'. Before I get into more detail, lock the Tone Arm in place and let it cycle to reset itself. With luck that may help. If not, here is my recent experience with my Dual suggests. Page 13 of SM gives you some info on the shutoff mechanism.
First I would disconnect that micro switch and get Power Switch wired correctly. This is an example of 120VAC USA model, do not know your service. The 4 pin power plug: White ground wire is on pin 1, pin #2 neutral from AC cord; pin#3 empty; pin#4 +AC from AC cord. Motor; green and black wires are on #3 pin terminal, motor yellow and orange wires are on pin #4 terminal. There should be a axial capacitor .007uf, 700V in the switch, part/position #163. It should be across pin terminals 2 (-) & 3(+).
Unplugged, you watch it operate and when you move the selector lever to off, the 'switch arm' (part/ position#147) to the switch contacts moves as the platter turns? This movement should flip the contact to the power off position, away from center spindle. If that #147 arm is moving, then maybe you can disconnect micro switch and wire it per factory. But first, if the contact does not move, carefully manually move it, to insure they are not fused. If not fused, and wiring is corrected, micro bending of the lever mechanism, where the rivet attaches #147 arm to contact via spring, would be the last step. You will probably bend it (1mm)to the outside, toward the open contact position. You can move contact it to see how it is a spring balanced see-saw action.
On vinylengine.com, I picked up a lot of info at their Dual Forum. Good tips!
