illinoisteve
... The motor is very quiet on these and if it's not touching anything you probably won't hear motor noise.
Mark:scratch2:
The motor CAN be very quiet, unless the bearings are as dry as the gummed up linkage, then it can chirp like a sparrow. If it is running quietly that is good. If it were noisy it might just need to be disassembled and have the bearings cleaned and relubed. If it really isn't running, it could be a problem in the power cord or the box or contacts inside where it attaches. I forget whether you mentioned trying to manually move the tonearm over the edge of the platter. If there isn't a cord or connection problem, that might switch on the motor, if not all of the linkage is frozen.
Just try a few little things at a time, each time plugging it back in and seeing if it made any difference. Caution is good.
Also, explore vinyl engine for a model that seems very close to yours that has a service manual. The service manual has some trouble-shooting question lists that might help you think through what issues are related to what problems and possible solutions. Even if not every bit of the mechanics are identical to your model, you could learn a lot from reading the service manual for a similar model.
:tresbon:
