Dual 1229 Advice
Decibel_116
AK Subscriber
I was given a Dual 1229 by a friend of mine. It looks like it has been stored for quite some time in a dusty environment. It appears to be complete with the exception of the multiple play spindle and dust cover. It also came with a CS40 wood base. It looks like it has a Shure M91E installed. I have not plugged it in to see if it works. The tonearm seems to have some play in the pivot points. I am wondering if this particular model warrants restoring or is this a "parts" table?
It's one of the best regarded Duals. Worth restoring unless you find it requires a lot of $ to restore, Don't force any levers if they don't move freely. Will probably require disassembly and regreasing/relubing to run smoothly.
I really like the 1219/1229 series Dual's. Have three. Two now nicely working 1219s and a 1229. Have a second 1229 that arrived from a very damp environment. Came without a base. Your 1229 is a keeper. You mechanically inclined? Find the sight here on AK about refurbing Dual's. A great help, even for an old warhorse like me. Also, go to Vinylenegine, sign up and get the service manual for a 1229.
My current project, the above 1229 is kind of ratty looks wise. It's has some rust on its black areas. Never saw this before. Had no automatic function. I did what I do with all Dual's. Start by removing 40 years of old dried grease. It dries out. There is a big gold gear underneath. Take cotton swabs and get rid of the old grease. I like using Lubriplate . Take a cotton swab and lightly dab lite grease into the gear. On my latest 1229, I ran it and had no auto return. Replaced the stuerpimple. It's the piece that runs the automatic cycle. There is a section on how to do that here. Usually at this point I will remove the motor, clean and oil it. On this 1229 I ran it. Worked like a charm. The arm dropped on the record and returned as it should. Sadly, one channel was out. The moisture rotted the wire on the right channel. It sat. If you remove the headshell on the arm you will see contact where the headshell makes contact. Found one on eBay with new wires. Hope your wires are good. Cleaning out old grease and motors are common on Dual's. Not a big deal. Arm wires a pain. Got the channels back! Usually, doing the above will get you going. Replace the audio cables. Even new ones can break. My 1219 did after a year and a half. Your 1229 is a keeper, good luck!
Eric
OK guys. Thanks for all the advice. I guess I will keep her and fix her up. I have always wanted at least one good Dual in the stable.
It's a great deck. Be careful of the speed control and the single/multi lever! Don't force them if they're sticky.
There's a great PDF doc that goes over all sorts of refurb steps for a 1219. The 1229 is pretty much the same.
