Beatkerouac
Eh, So to start off, I had my dual 1229 serviced a year ago and everything was working fine. Then this started happening.
So today I decided to take the unit off of the plinth and turn it over and see what i could find. I'm not a pro and I wasn't in a rush to call the guy who serviced it because I should have had some good years without any problems. I didn't adjust anything, I just put it back together and gave it a test run but now the auto start/stop isn't doing anything EXCEPT when I tilt the whole unit up about 45 degrees. Everything works just as it should, I don't have the original problem shown in the video. Keep in mind the tone arm is on lock and i'm just testing it that way. So, when I set it back down level the start stop lever is "locked" and won't move to start/stop positions. Recap when I raise the turntable about 45 degrees to see what is happening underneath everything works fine.
As for the original problem shown in the video, I have tried to do the cycle with the tonearm on lock. I have no problem working it manually but I'd like it to work as it should.
