PJHARRIS123
Hello. New member here.
So I cleaned up a Dual 1229 that was actually gifted to me and the motor seems to be a touch slow. I removed almost, if not all, the old grease and replaced it, took the motor apart to re-oil the felt, re-glued the strobe ring under the platter as well as a lot of aesthetic revitalization. I even polished the platter before finding out they never shiny. Whoops.
I even bought a new Cambridge Audio amp to celebrate and to my dismay, it’s just a touch slow. I played with the pitch knob and that didn’t do much. I’m nervous that when I put the motor back together, I went a couple threads too tight. Nothing is rubbing but it’s very warm to the touch which I’m assuming is normal?
I read there’s some sort of speed adjust screw that moves the pulley up and down on the wheel but I’m not seeing anything. Anyone have any ideas? I should mention the guy gave it to me because he thought the motor was dying and I’m assuming he had the same problem.
