redpackman
I am working on a Dual 1229 for a friend. Looked to be in very good condition. Original box, all the doo-dads. But it's turning into a nightmare. I've worked on lots of Duals before including 1229's but it appears this one has been tinkered with ALL OVER and it's all out of wack. The controls and sticky stuff that are usually the problem on this one are in great condition. as is the motor etc, but the tone arm movement is a nighmare. Probably 15 hours on it already and total frustration.
Here's the issue as stated in the service manual (yes i have it). Dual 1229 turntable "tonearm doesn't raise from the tone arm rest with mode selector in the "multi" position." Service manual makes NO sense on this. "Adjust the equalizing arm on the eccentric piece of the protecting plate so that with the main lever pushed down the balance place sits a minimum of .6 - .8mm on the lift bolt.........
What eccentric piece? Not obvious to me.
And this is just ONE of the many maladjustments this unit has.
Help
Help
