shacky
Addicted Member
When mounting cartridge to standard Dual cartridge mount I know the VTA is set for 3rd record. So using a spacer between mount and cartridge would help correct geometry for single play. I do use the changer function but would never put more than three albums on and usually only two.
Using the washer like spacers that come with mounting accessories moves the body of cartirdage away from the mount which is what I want but also reduces the area of contact between the cartridge and mount. So it won't be as solidly connected to the headshell. Unless I could fabricate shims the sames size shape as the top of cartridge - which I don't think I'd be good at doing.
So my question is - how important is it to have the cartridge solidly/rigidly connected to headshell?
