javajam12
Hi - I just bought a used Dual 1264 complete with original box and packing
materials, manuals, etc. for $40!! It is in beautiful shape. I replaced the
broken stylus and bought new belts. I can change the main belt, no problem.
How do I change the pitch belt and how loose should the pitch belt be? I don't want to change it if I don't have to. It appears intact, speed seems ok
but fluctuates a bit. The pitch belt appears a little loose to me. Is that
normal? Any advise? Ovenmaster, want to chime in, feel free! Thanks - Jon
. Mine's a smidgen loose as well. If the speed fluctuates a bit after you've adjusted it, I'd say that you may have a problem with the Variopulley assembly (parts #14, 51, and the un-numbered part sticking out of the top of the pulley #15). Just my two centavos...
