I have continuity from the clips on the back of the cartridge to the RCA'S
The hum gets louder when i touch the arm.The music seems louder than before but the hum is still there.
Should it still hum with the cartridge unscrewed and removed?
When i play a record and disconnect the RCA'S from the amp should the + on the two RCA'S have continuity through the multimeter.The - has continuity with this test
Well, you certainly should have continuity (very low resistance) from the hot pins on the tonearm, to the centre (hot) pins on the RCA plugs. You can’t call them “+”, because the audio signals are alternating current – they change sign, from positive to negative with respect to earth, at audio frequency. All four pins on the tonearm (that the headshell plugs into) should get continuity to the respective RCA plug connection, and obviously they do, as you've tested them to the cartridge pins.
However, you shouldn't have continuity between the earth (outside) RCA pins of both channels, when they are removed from the amp. if you have, you'll have an earth loop, which, because it will be within the electro-magnetic field from the amp's transformer, will pickup hum at mains frequency - a small alternating current, at mains frequency, will then circulate around the loop. The only place they could be connected together is inside the turntable, and they definitely shouldn't be connected together at that end. That is, there should be no wire to connect the blue wire from the tonearm, to the green wire. They may be signal earths, but the only place they should be connected together is inside the amp circuitry.
Have you tested the turntable earth lead, to see if there’s continuity between the amp end of it, and the metal of the tonearm? It makes me think there's something wrong, if you hear more hum when you touch the tonearm, if the earth is properly terminated at the amp's phono earth terminal.
I don't think it should hum when you remove the headshell and cartridge off the tonearm, unless there's an earth loop - there won't be any path for any signal if there's no loop, as it should be open circuit at the headshell connection pins on the tonearm.
Are the signal leads definitely shielded (a woven wire shield, and perhaps other shields, like some foil, inside that, and around the centre hot wire - similar to this
http://www.altronics.com.au/index.asp?area=item&id=W3000 )? If, for instance, the wires are twisted pairs, they won't be properly shielded against hum pickup from house wiring and things like that.
