moondogtn
Well-Known Member
I picked up a dual 604 with the anti resonator counterweight. Later, I saw that it was sagging and research began. I’ll try to describe this clearly.
The perpendicular set screw that holds counterweight to to arm is present.
There are two holes in the end of the counterweight assembly itself. One in center and one that I assume will be at 12 o’clock?
There are no screws here.
I assume there should be at least one screw that will go through, tighten up to the bar but and hold the counterweight in place?
Does anyone happen to know the size of that screw?
I’ll double check the manual but did not see exploded view of the counterweight.
I have searched as there are meant threads regarding these issues but none show pics or have screw size(s).
Thanks for any guidance on this.
Bill
Bill
