Dual 620Q auto return issue
I see nothing about the pimpel
See post #3, starting at "Bild 12" (pic 12), which Wolfgang apparently forgot to embed, so you'll find that pic attached at the end of post #3 instead. It shows a bottom view of the drive.
Pic 13 then shows the Steuerpimpel (marked with a red oval) below the main lever.
And in pic 14 you can see the already removed main lever on the right side as well as the Steuerpimpel again, this time marked with a green oval. And pic 15 shows the part, from which the main lever has been removed. Mind you, though, that removing the main lever merely makes it easier to access the Steuerpimpel - but it's not an absolute necessity to remove the main lever for swapping the Steuerpimpel.
Greetings from Munich!
Manfred / lini
Difficult... there is no pic 13 and the latest pic at the end of the post is not reachable even connected (Der Zutritt zu dieser Seite ist dir leider verwehrt. Du besitzt nicht die notwendigen Zugriffsrechte, um diese Seite aufrufen zu können.).
Photos are so small as well.
Hmmm - strange... Because I can see pic 13 - and when I click on the attached pic 12, that also opens no problemo.
But maybe the direct links to the pics would work for you.
Pic 12: https://www.dual-board.de/core/index.php?attachment/196107-dual-cs-150-2235-rep-12-jpg/
Pic 13: https://www.dual-board.de/core/index.php?attachment/196108-dual-cs-150-2235-rep-13-jpg/
Manfred / lini
Well, I tried again the no translated website and it worked.
This Dual unassembly process looks not as an easy job!
Well, it could be worse. But in case of this family of Dual-Thomson era models it's indeed not as easy to access the innards as in case of most Dual-Steidinger era models (or also as in case of most Dual-Schneider and Dual-Fehrenbacher models).
Manfred / lini
