Dual 721
kwatch
I noticed the Dual 721 on local craigslist. It has something odd looking bolt on it. Do you know what might it be?
Nothing is supposed to be in that spot, it is probably just a sticker, looks a bit like a BBS wheel.
I would make sure all the auto features work, holds speed, though a cleaning would be due. I had to replace the IC's on mine.
It came with the Audio-Technica CS-112SII cartridge. Is it good one?
All the auto features works and it holds speed well. I have one issue. The stylus set down maybe one groove too far inside. I tried to adjust but the adjustment screw did not move. I did not want force it and break it.
That will take an Audio Technica AT12S stylus, which is superb. I use one. Not cheap but very detailed.
Dual 721 has two antiskating options, Conical or Elliptical stylus. I choose the Elliptical, right?
That is correct. :music:
There is also a CD-4 setting, use that for the Shibata stylus.
Thanks for the alert - highwaychild. :thumbsup:
You can download the user manual on vinyl engine. It will give you the information there, the table had a lot of nice functions to it
The 721 is a very respectable Dual table. I have a 1219, 1228 and a 1229 and would like to add a 721 to the stable. Congratulations!
