Dual CS 1268 low rumble
hrtattckcity
AK Subscriber
Ignoring all the reasons not to start trying to rehab an aged plastic turntable, I started to fix up a Dual CS 1268.
After an initial belt replacement and new stylus in the original Ortofon ULM cart it seemed to be doing pretty well with manual operation. I primarily tested it using headphones. As I began to troubleshoot some of the other issues it is having, it has begun to have a low, feedback-like rumble in the woofers when played through speakers at moderate volume. The woofers begin to vibrate wildly like the test cd from looneytunesrick's refoam kits.
I know I need to find or fabricate a replacement steuerpimpel, but I assume this would not be causing this issue.
Any suggestions on what to look for?
I did recap the motor control as once it did start spinning backwards.
thanks.
Placement.
Your turntable is not isolated from the speakers adequately. It's too close or on a surface that is influenced by the low frequency vibration from the speakers. You need to move things around, looking for ways to isolate the table such as a more solid floor or furniture or perhaps wall mounting.
D'oh! Speakers on the workbench. Thank you.
Placement.
