forgetcolor
Picked up a decent looking Dual CS-506 from craigslist for $5. Figured I'd fix it up and give to a friend. It needed a belt and a new RCA jack. I soldered on two new jacks, got and installed a belt, balanced everything up, and plugged it in.
Only signal on the right channel.
I checked my solders, they all looked good. I got out my multimeter, and the continuity from jack to headshell wires make sense (right signal on the jack to red on the headshell wire, etc.). So I figured it must be the cartridge that came with it, so I swapped them out, but no dice. Still getting only the right channel.
So what gives? How could I get continuity from the jacks to the headshell as expected, but only get one channel w/ two different cartridges?
Thanks
Thanks
