Dual Neon Tubes
NoTransistors
Dual Turntables Super-Restorer
Had a ton of them, all new and unused, that has just run out. These things don't simply burn out like a normal incandescent. Sometimes, they will give an obvious, constant flicker. Others might start to not follow the A.C. frequency. This makes you think that there is something going on with line frequency, or with the supporting circuit [2 resistors, a cap and a diode], which is rarely the case.
Anyway, I simply would like to know what your opinions are on the L.E.D. aftermarket replacements.
Thank You.
Often they are okay but the ends are oxidized and just need a bit of burnishing with an ink eraser or a dry Magic Eraser to make them work (it wouldn't hurt to brush the ends with a bit of Deoxit. If the tube has a red mark on it MAKE SURE the red mark is placed in the holder with the dot closer to the diode. I'm operating for 10 years with the same tube in my 1249.
Do you mean those little neon bulbs with wire leads? Didn't know that such things are still being made. They are old as the hills.
I wonder how it looks in the available green. Those little old neon bulbs were at one time available in green as well.
