Dual plinth templates
MrMark
I want to build a new plinth for my 1249. Does anyone know if there exists a template for this? I see vinyl engine has one for the 1219 that looks awfully similar... any thoughts?
It should be the same....
Hope so. I am bidding on a 1229 with no pith. Got a 1249 from the landfill that Bohley got. Kept the base and cover. Its a cheap plastic one which will have to do for now if I win it. Not a big deal as this one will be on the shop system while I go through it then into a cabinet with doors in the livingroom.
Getting too many again. May have to let one of my 10 Series go. Got three plus a 1219. Getting back a 1229 would bring the total to 5:D..running out of room.
Eric:music:
You could trace the opening and mounting points from your plastic base, I suppose. Seems odd that a 1249 came with a plastic base since it was supposed to be an anniversary model. Many of the large chassis 12XX series share the same mounting so anything is possible.
I have a 1242 here that I was thinking of robbing the 860 motor from but it's in too good shape to turn into a parts unit and the double speed problem of the 840 only happens occasionally. Keep an eye out for a 1237, 1242, 1245, 1246 or a late 502 for the 860 motor.
I moved it over the the similarly crappy plastic plinth of my 510, and it fits, thought the plinth on that one is a little bit wider, the mounting pattern is identical. so i assume all the 12xx series have the same pattern. The things are relatively well made, otherwise, especially the 1249, and I cannot for the life of me understand why they would not have charged an extra 10 or 20 dollars back then to have a decent plinth...
