Dual Shure Combinations
Cylontymany
Could someone give me a lesson in what Shure carts came with certain tables? I have a CS 601 that sometimes came with V15 III carts. I have seen DU DM and others but would like to know what these designations are and so forth. Thanxs
Not the complete list:
DM101MG (M91)
DM103MG (M91)
DU10-M75E TYPE 2
M75E-D19
M75E-D19 TYPE 2
M75MG-D
M80E-D (M55)
M80E-D19
M91E-D12
M95HE-D
V15II-D12
V15III-DM/DU
These models were pre-mounted onto Dual headshells.
Shure cartridges were commonly fitted to Dual turntables in general, at least until the advent of the ULM arm. My 1218 came with a Shure Pro-7 (M95 variant) installed, and I bought a 1219 tonearm off of eBay whose cartridge sled was fitted with an M55E. Both of these were normally mounted using screws; the D/DU/DM cartridges, as mentioned above, were pre-fitted to Dual cartridge sleds using glue. I'm not sure that any Dual models were always fitted with a particular Shure cartridge by default; Dual offered their own cartridges even before the ULM era.
-Adam
Ctm: You'll find overview lists in the Dual Zubehör (= accessories) catalogues, of which you can find some on the catalogue page of the Dual section of Lulabu's archive: http://wegavision.pytalhost.com/dual_k.html You'd better look (and maybe better also save what you need) soon, though - 'cause as far as I'm aware Lutz' free hoster Pytal is going to close down soon, and Lutz is currently still looking for a new home for the archive, so that it might be inaccessible for a while.
Greetings from Munich!
Manfred / lini
Manfred, Hi!
The main website from which you got the literature from is gone. It listed Dual models, plus their sales brochures, repair manuals, test reports, etc. Was absolutely wonderful. Where did it go?
Seth: The main Dual page should still be accessible at the moment. Same link as above, just without the "_k".
And as I've read earlier on the German Dual-Board, Lutz supposedly is already confident, that he's found an alernative.
Manfred / lini
How would this be in any alignment?
I have never understood how this is possible and I own the jig!!!
This came with my 601
Same cartridge shell as the 701. The cartridge snaps right off so the shell can be used with other cartridges.
ctm: Over here none - because over here it came with the Dual M20E (which is similar, but not identical to Ortofon's own M20E Super).
Manfred / lini
My CS 1246 has the M44c cartridge (I don't know if the TT originally came with it or if someone installed it). Its a good combination that doesn't have hum or background noise issues, and does well with recorded voices.
Have used the v15 type III on a Dual 1229. Used screws. Qaulity varies. I did not like it. Got another one recently. Came with a parts Garlard Zero 100. The V15 was a bonus. Put it on another Zero 100. This one is great!. Sounds terrific. This uses screws too. Recommended.
The used Dual 1219 I acquired has what appears to be a factory installed metal body M91. Still works like a champ and sounds very nice with the 4 different styli I have. My favorite being a Jico HE from TuntableNeedles.
The used Dual 1219 I acquired has what appears to been a factory installed metal body M91. Still works like a champ and sounds very nice with the 4 different styli I have. My favorite being a Jico HE from TuntableNeedles.
My early 1219 has a M91ED. That too is recommended.
Wow! Thanxs a bunch! I have missed a few opertunities to get a V15III but I am not willing to pay into the hype especially if a cart is minus the original stylus. Far as Im conerned Shure has been out of it for many years but now that they finally made it official some folks are going to try to jack the prices up.
There's no "hype" when it comes to the V15 lll. It's simply an excellent cartridge. Fitted with a JICO VN35E or even better, the VN35HE, you won't need an original stylus.
https://www.jico-stylus.com/product_info.php?cPath=18&products_id=1044
https://www.jico-stylus.com/product_info.php?cPath=18&products_id=1046
The 1246 would not have come from Dual with the M44C cartridge. That cartridge originally came with the N44C stylus (light blue grip) which tracked between 3 and 5 grams and was intended for changers or beefy tone-arms.
I don't know what stylus you have but a better stylus for that cartridge mounted in the Dual 1246 tone-arm would be the N55E (yellow grip), it tracks between 3/4 and 2 grams.
I remember you telling me this in another thread. I may try that route instead of replacing the cartridge. The cartridge seems to be in working order, and (like tires) I dread replacing cartridges because they are darned pricey.
