DUAL Turntable Guide 1229, etc..
richaudio
Does anyone know where I can get the Dual guides for Dual 1219, 1229. others. This is the little white cap that goes over the metal rod that moves when the tonearm is cycling. These wear out and then the tonearm will not cycle properly. I would like to order a quantity if possible. Thanks
Or do like many of us and make your own. I used a Bic pen refill, just cut off about 1/8 inch of the little plastic tube. Other folks have used pieces of wire insulation or even heat shrink I believe.
