supertack
First off, why does the AU-717/919 integrates have 'power amp in' jacks? Was it intended for a power amp to be connected to that unit? If so, why would you connect a power amp to an integrated that already puts out a ton of power?
Moving on, assuming your working off the same AU-717/919 as a power amp, do you need a 'power amp in' jack on the unit your using as your integrated to get it to function properly?
I already know the integrated that I own (which I love & wanna use) does not have a 'power amp in' jack, but want to experience the 70s quality you folks are so fond of in the AU units.
Is there a way to connect an AU-717/919 amp in a power capacity to an integrated which only has in jacks for 'tuner' 'aux' 'phono' 'tape' & 'eq'?
Thanks, always good info.
A taste you don't forget!
