Dumb radio antenna question
Wally Swift
Banned
My brother asked me this and I don't know the answer because I'm not a radio guy. The only reason that I ever turn my tuner on is because I like the way it lights up the front of the receiver!
On the card that came with my 2000X is tells me that;
The black bar on the back is for local AM reception
There is a single "input" for an AM roof antenna for distant reception.
There are also 75ohm and 300ohm dual inputs for FM.
Am I correct in assuming that with such a unit if I hookup a roof antenna to the single AM input that is for distant reception it will also help me get better local, AM reception?
Thanks.
I doubt a roof antenna is going to give better am reception. It was designed for uhf/vhf and fm reception. A long single wire would most likely do a better job for am.
If you hook a roof antenna to a stereo or anything electronic for that matter, the lead should be grounded with a pass through grounding block. Otherwise it's like running a lightening rod right into your house. Not safe!
