Dust cap removal help
so it looks like you found the break then .. just needs fixing now .. maybe its as simple as adding solder to the break ..
failing that a new tinsel wire should fix it .. it can be a bit fiddly i know ..
Thanks for the input. I'll try and get a look at that solder joint. Might put it off as I have just cleaned up the tweeters to refoam them.
