Dust Cleaning
randyrhoads1
RandyRhoads1981
For cleaning the dust off Reel To Reel Tape Decks, standard dust cleaning is fine, right? It won't mess up the circuit boards or anything?
After spraying, do I need to wipe anything off?
Any other steps or tips for cleaning in general?
thnx,
Thomas:thmbsp:
Canned air, a vacuum cleaner with a thin tube nozzle, and soft brushes will get most of the floaty stuff out. Foam swabs & Q-tips moistened with Simple Green for a more aggressive aproach to build up on PCB's.
Use care around components like capacitors, transistors, and resistors, or you can create cold (loose) solder joints on them, creating more problems.
I thoroughly cleaned a Revox PR99 that has most of the circuit boards plugged to a backplane board. These boards, along with the backplane, were removed and thoroughly soaked in warm tap water and hand soap. For contacts, I used an old soft toothbrush primed with soap to make sure they became shiny. Then rinsed with 95% alcohol to drain most of the water and finaly dried in the oven at 40 degrees Celcius (~100F).
I've read in the past about cleaning PCBs like this but I've also read criticism on doing this.
