Dusting tube amp
bajaed
I know a lot of people recommend canned air, which I will use as step two, but I worry about blowing dust into the amp.
Does anyone use a small duster like a swiffer to dust the surface of the amp and maybe run lightly over and around the tubes to remove dust?
When cold and unplugged, remove tubes and gently wipe down with old T shirt. Rest is rag where I can reach, alcohol and cotton swab in tight spaces. Let dry completely. When there is debris involved, I will cut the head off a q-tip and use the shaft to dislodge it - gently!
Shelly_D
i use cheap paint brushes and acid brushes for the most part, usually with no cleaner or water.
I have a Bob Latino ST120. I got a tip from someone... Use a Silicone cloth they sell at gunsmiths to clean a gun. I don't get this on the tubes... But the steel and the trannys (Painted Black) I use it.
