Are you looking at a build from scratch, or a kit? There are a lot of nice kits.
Dynakit, Tubes4Hifi, etc. There are also blank printed circuit boards and you supply all the other parts. Tubelabs sells some excellent bare PCB's with parts lists. I've built the Tubelabs 300B SET amp using his PCB. He also sells an SE amp board that an be configured to use 6L6's, EL34's, and KT-88's. It can alao be wired triode mode, pentode or ultra linear. He also sells a pcb to build a push pull EL84 amplifier. The Dynakit and Tubes4HiFi amplifier kits are very nice kits. The instructions are excellent. I built the Tubes4HiFi ST-70 8 years ago and I'm very happy with it. I recently built the Dynakit ST-35. It's also a great kit. Both sound very good. Erhard Audio sells a few amp kits as well I think. I've built one of his preamp kits and bought another that was prebuilt.
View attachment 1854062 View attachment 1854063
The amplifier kits from Tubes4HiFi or Dynakit are very good with excellent instructions. Both sell versions of the ST-70. Dynakit is most like the original, while the Tubes4HiFi uses an updated driver board with bias adjustments for each output tube. Dynakit also sells several mono block amps as well as the smaller ST-35. If you want lower powered single ended amps there is Bottlehead and a few others that sell nice kits.Probably a kit. Since I'm not an electrical engineer lol. My experience with electricity is more on the DC side. And I wouldn't even know where to start designing an amp from scratch
Depending on your speakers Bottlehead makes great kits, almost moron proof assembly instructions, great photos and great forum.
Hello HFM,
I will probably get a load of stick from the tube aficionados but never mind
You would like to hear the 'valve' sound, there is a very inexpensive way to do that. In the 60's a state of the art valve amp was designed by a Mr Williamson it was the bench mark against which all others were judged. Constructors all over the world are still making them.
Along came a Mr John Linsley Hood who was a electronic engineer at the Windscale nuclear re-processing plant, he was interested in audio and also at the cutting edge of electronics. He designed a very simple Class A transistor amplifier and in 1968 he and other audio friends set up a switched trial, two valve amplifiers one of which was Mr Hoods own DIY and expensively made Williamson, his own Class A transistor amp and three class B transistor ones, one was a commercially made effort.
The conclusion was very interesting the amps fell into two camps on one side the Class B amps and in the other the two valve amps and the Class A transistor. Of these three the Class A transistor and the Williamson sounded better than other valve amp.
The sentence in the article that he wrote that is the most telling is this; "The "Williamson" and the present Class A (transistor) design were both better than the other valve amplifier, and so close in performance that it was almost impossible to tell which of the two was in use without looking at the switch position"
The article can be downloaded here: https://drive.google.com/file/d/1p5k4YgTPAYa-aCtt6DpfE6CCekHOhV6k/view?usp=sharing
Not much danger of electrocution either.
Cheers - J
