Last month I posted trying to ID a mod on an ST-70. I now know that it was for 6B4G tubes, I found 4 that I had tested 20 years ago. I was confused about what I had done because I forgot the 6B4G is a triode and I kept thinking that I had just planned to put the 70 in regular triode mode for the EL-34s. I also removed the 500 ohm cement resistors replacing the .02 cap in the bias supply thinking they were not needed, and replaced the .02 cap.
I was thinking of returning the ST-70 to stock operation but I would like to try the 6B4G's first after having done all the work long ago. I did put them in, and moved the Voltage up slowly, at about 60 volts the static started and around 85 volts a bit of music began coming through, this lasted about a minute and then it all stopped and there was a bit of hum. I shut it down. There had been no burn smell, no flashes or red plates, nothing obvious. I believe I need a schematic and instructions for the 6B4g mod so I can make sure things are right before I proceed. These pics show the connections to the front sockets. I now believe the wires to the bias pots had been moved to ground because of the bias arrangement for the 6B4Gs. The Cerifine cap is 47uf, and is the first B+ cap from the 5AR4. Where can I find info about the 6B4G mod. Thanks for all the help. Happy New Year.
