Dynaco A25
HeyJB
I recently acquired a pair of Dynaco A25's (Scanspeak version). One speaker has noticeably weaker low end than the other. I tested them side-by-side with 2 separate receivers, using every combination of speaker terminals and speaker wires. I haven't yet tried to swap the woofers.
Could this be a crossover issue or is it likely a problematic woofer? Anything else I should consider?
I have a pair of A-35s that had the same problem. Turned out one of the woofers was toast. You may have to pull it from the cabinet to test it, and it may very well be glued in, requiring some careful prying with a lever of some sort like a flat head screwdriver
