trainbuftony
Electron Herder
I got this pair from a fellow at work, the thread about how I got them ran its course and as promised I'm going to rebuild them. This thread will have that information in it and then there won't be 6 extra pages on how I found it and all of that other stuff. I found these from a guy at work, he took them out because he heard me talking about tube equipment and I made him an offer he couldn't refuse. He's 82 years old and probably doesn't have any interest in ever fixing stereos again after having done it professionally for 30 years.
This is how they arrived hand built, and unmolested.
I had a project occupying the front burner at that point and couldn't put them on the bench. I put them upstairs in the queue and let the ideas brew in my head as they do... My thoughts were to either mount them on rack panels and use the bottom as the face, or to build a bottom panel and wrap them in a walnut skirt.
I opted to go the way of the walnut skirt so my first order of business was to clean off the sides of unwanted mumbo-jumbo and relocate all of the necessary connections to the "back" pannel, the transformer end.
Tubes naturally want to be up front, on display with the "big iron" right behind them. Today I finished mounting terminal strips, iec jacks and rca jacks on both amplifiers and got them ready to fire up and check out.
Often times when you find a piece of diy equipment you'll discover that the builder used unconventional means to attach speakers to their system, signal wires are the same way. They used funny deutz plugs because they probably had those and lacked a parts express catalog and smart phone. So before I even think about firing this up, I need to get the connections figured out. That's done.
The other thing that must always be done before applying power to a dormant amplifier is to replace all of the electrolytic capacitors. I find they don't age well and I change them out for new. Every electrolytic, every time.
The guy who built this particular amp must have had a head on his shoulders because rather than using the conventional clamps, or mounting wafers, the builder of this amp put all of the electrolytic caps on tube bases, plugged into tube sockets. A full recap takes under 1 minutes time. You simply unplug 4 old caps and plug back in 4 new caps.
Hayseed will make em with octal bases.
My mind is completely blown.
Anywho... today is the day we fire one up and see weather it makes any power!
They've been recapped, the inputs and outputs figured out, and extra parts have been removed. I love how my cloth wrapped wire blends seamlessly with the antique cloth wrapped wire that's already here...
