Dynaco Mark III Light show ????????
harleyrider
Well i just walked in from work and thought i would put some tunes on . Went over and powered the 1st amp up (Dynaco Mark III ) and within seconds i heard something crackling and looked over and the rectifier tube had a light show going through it and got very hot . It all happened so quick that before i could get back to it it was over !!!! Now nothing , have not took the bottom off just yet to check the fuse but i am thinking something fried bad. I have 2 of these amplifiers left and right and have been using them with no problems so far . The 1 amp with the problem has been recapped prior to me owning it . Both of these amplifiers are ran to a extension cord and then into the back of my Yamaha receiver that i am using for a preamplifier for now . I had the amplifiers powered off because i had been using the Yamaha for HT using its own power into its own set of speakers. I only power the Tubes up when i want to listen to music. I did power the amplifier up before the receiver , not sure if this would cause something or not ? . Any ideas of what may have caused this ? Both amplifiers still have the rectifier tubes i bought them with (5U4s) instead of the original 5AR4s which i just have not been able to buy just yet . I dont know if it was the way i powered it up or if there is a problem elsewhere ? I need help here please .
Thanks
Chris
Hiya,
Well it could just be a bad tube. Do you smell anything burnt and can you provide any close up pictures of the underside of the broke amp ???
Frannie
Frannie, i will here in a bit . Tyring to relax a bit now, so ill get some pics up in the next hour or so . I just do not know what the heck is going on seems it always something . Ya i know i am going to go through these soon but they have been working nicely . The only problem i have had is i noticed what i called a bit of distortion that comes from this amp in question . In my other thread i mentioned this distortion problem also . It seemed that when i was listening the longer i listened or the louder i tried to push it i would get this distortion (in the highs) or at least that is were i heard it ! I did a process of elimination and narrowed it down to the amp itself .
I will post some detailed pics here in a bit
Thanks
The fact that you were getting distortion in one amp was most likely indicative of an impending problem. Are there any Ak members in your area that can lend you a hand troubleshooting?
Hiya,
Well the fact it was the rectifier arcing may be good news. Its past the power transformer so that is still likely ok as long as you shut it down quick enough and its not the OPT.
And you were going to rebuild these anyhow so could be worse.
Hang in there it will be ok I am fairly sure.
Frannie
No one around here that i know of ? Here are a few pics of what i have .
And yes the Fuse is blown !
Do you happen to know if the new capacitors were simply added in parallel to the old can-type capacitor?
Good point. Can you take a couple of close-ups of that choke?
Glad to hear the new caps weren't simply added in parallel to the old ca-cap.
It has that old electrical smell, but burnt well thats hard to say really . Is there anyway to test the chocke in circuit or out ?
Im not real good with close ups they seem to blurr on me .
So with out going into to much detail in this thread , what does a choke do ? And is there away to test .
I forgot to mention in the beginning of this thread , when i was eliminating the causes of distortion in this amp i did swap tubes from one amp to the other one at a time . But the distortion stayed in this amplifier .
Hello,
Well you can do a resistance measurement on both your good and bad amp. Pull the rectifier or pull up one end of the choke and compare readings.
Its a 1.5 Henrie choke. Not sure what that show show as on a ohmmeter.
Frannie
Here are pics from the 1st day i got the amps . Showing both for comparison . Looks the same to me ?
The Dyna chokes in the MK III can get toasty looking just from years of use. In my experience, when they fail, they short their internal winding to themselves, not to the frame. Check the choke by measuring its DC resistance. It should be close to 60 ohms. This can be done with the choke still connected in circuit. If it is significantly lower than this, it is internally shorted and should be replaced. Of course, if the winding has shorted to the case, then it obviously needs to be replaced as well.
The key here will be how quickly the event happened after turn on. If it happened quite quickly -- say within 10 seconds or so -- then the problem is clearly power supply related. If it happened after say 30 to 45 seconds, then the rest of the tubes are starting to conduct, meaning the problem could extend into the audio circuits, causing the rectifier tube to fail. Assuming the new filter caps are good and have not failed prematurely, my bet is the 5U4 simply went south. It can, and does happen -- but check the choke too in your trouble shooting just to make sure.
Dave
Hello,
I am going to use another persons wording to explain what that choke is doing.
Why use a choke? Why not just a big series resistor?
A choke is used in place of a series resistor because the choke allows better filtering (less residual AC ripple on the supply, which means less hum in the output of the amp) and less voltage drop. An "ideal" inductor would have zero DC resistance. If you just used a larger resistor, you would quickly come to a point where the voltage drop would be too large, and, in addition, the supply "sag" would be too great, because the current difference between full power output and idle can be large, especially in a class AB amplifier.
Frannie
PS: Its in the schematic in the part I snipped and attached (drew a ellipse around it) ..
Of concern to me is the fact you're running 5U4 rectifier tubes which draw 3 amps of filament current vs 1.9 (or 2, depending on which data sheet you're looking at) for the 5AR4. I can loan you a set of 5R4 rectifiers which draw 2 amps of current and drop a bit more voltage than the 5U4. They should work well and not tax your power supply transformer.
Of course, we need to figure out if just your 5U4 went south, which if a plate was failing could have explained the distortion when you turned the volume up. Just a possibility.
A choke also has a collapsing magnetic field during heavy music (current) peaks, which helps hold the voltage steady.
Ok well before i get to far here , dont i need to de energize these caps ? I have read a thread here about this but i dont believe i have the correct resistor to do this with. Is there another way and which caps is it im going to do this to ?
I did pull the rectifier tube and all other tubes as well , did a resistance check using my fluke (ohm) meter and was getting 62.0 ohms . Choke still in circuit ! Not sure if this would be correct or not , but i didnt want to desolder anything until i got this discharged . If i need to ?
