Lavane
Lunatic Member
Are the boards you bought copies of the VTA octal board?All you need to do on the Mk3 octal board, depending on the parts list, is increase R39 between the two bias filter caps. It would help to have a schematic for the octal board. I bought mine from an eastern European seller that makes/markets the auto bias boards. It was a driver board/bias board combo. I think his original R39 was less than 20 ohms. Changing to 470 ohms reduced the ripple on the bias voltage quite a bit.
Here's ripple with the stock resistor value at 0.5V vertical scale.
And after increasing R39 to 470 ohms. Same vertical scale.
Is there even a difference parts values wise, like a few resistor value differences between the 12AU7 and 6SN7 VTA boards? Or are the sockets and tubes used the only difference between them? There isn't much difference in gain , and some have used 6SN7's on the 12AU7 boards with socket adaptors. I tried a 6SN7 in the voltage gain socket of my 12AU7 ST-70 board. I didn't leave it there though.
I just didn't care for how it looked having to use the octal socket adaptor on a 9 pin socket. I'm surprised someone hasn't traced out the VTA octal boards and posted a drawing anywhere, like here, or at DIY, or the Dynaco Forum.
The schematic for the VTA ST-70 using the 12AU7 tubes comes with the amp kits, but no schematic for the amp using 6SN7's even if you order the kit with the 6SN7 board instead of the 12AU7 board.
