I get that there seems to be some real performance benefit in bypassing the tone controls in the Dynaco PAS2 and PAS3, but what about the PAS 3X?
This PDF from Pacific Audio Regenesis clarifies the benefits to the PAS2/3, but I'm still confused as to the benefits to the PAS 3X...
"If you do not use them, bypassing the tone controls is, perhaps, the simplest modification you can make to your PAS 2/3 that results in a measurable, and often audible, improvement in performance. The primary benefits include increased drive capability and improved linearity. As well, the already very low distortion of the PAS 2/3 is further reduced at the low end of the audio band...
....Note that the PAS 3X incorporates special tone control potentiometers which are automatically bypassed when set to the center position."
Does this mean that the 3X is the standard to which the 2/3 mods try to achieve? Am I missing something obvious, here?
http://www.audioregenesis.com/documents/PAS Tone Control Bypass.pdf
