Recently acquired a PAT-4A for $30.00 on CL.
Was functional as brought home, but was completely original.
Existing caps were all 1971 vintage, so assuming that was the build year.
Just finished stage one of the rebuild.
What a pain it is to flip up those boards without unsoldering all the leads from everywhere else.
Replaced every one of the old electrolytics as per stock schematic, with the exception of the PS filter caps.
Of which all sections were replaced with 1000uf 100v which I tied together with a pull tie, used hot melt for permanence and epoxied onto the floor of the unit.
Subsequent to the recap I ran a Sony CD player into the unit and sent the output into a rebuilt ST-150.
This was driving a pair of AR-2Ax.
For all the bad press the PAT-4 has gotten over the years, I was pleasantly surprised at how nice this puppy sounds. I also ran an AR-Xa with a Shure M-91E into the phono input. The quality was quite acceptable.
The phono input was a wee bit noisier than I'd like.
Next step with the rebuild will be to replace all the carbon comp resistors with new metal film.
After all that is complete, I'll be able to listen to what the original design intent actually sounds like.
At that point, I'll try the various mods, starting with the darlington swapout.
Why do all this to a lowly PAT-4?
When I was a kid, I wanted to assemble a system containing a PAT-4 and a ST-120
I rebuilt and tried out the 120 with a PAS-3, which was OK but the 150 is in a different league.
Here a couple of pics taken after re-assembling the unit prior to putting the cover back on.
Any comments or PAT-4 rebuild experiences that anyone else may have had would be most appreciated.
Cheers!,
Lou
Cheers!,
Lou
