shelly_d
Not An Audiophool
Hi all:
I have a question about the Dynaco PAT5. The one I own I've had since new and it is NOT the BiFet. The only schematic I can find online is for the BiFet version. That had a switch on it to provide an additional 6dB gain on the phono preamp to allow a moving coil cartridge with it. I've go a couple of questions about this.
On the BiFet version, the emitter resistor of Q1 on the phono board is 470 ohms. Operating the switch adds a 412 ohm resistor in parallel to that.
I do not have access to a schematic for my version. I am reluctant to try to dig into my factory assembled unit before actually attempting what I'm considering. I have a few questions, perhaps not all answerable by the same person.
1. Does the non BiFet and BiFet version share the same phono circuit, especially in respect to that 470 ohm resistor?
2. If anyone has the BiFet version, does the phono section sound the same to you in either position or does the added gain change the sonic character of the preamp?
3. Has anyone found the moving coil position inadequate for the output of a moving coil cart either sonically or with respect to the gain? If sonically, did you also find the same issues with the phono preamp set for moving magnet carts?
Thank you all for any help you can provide.
Shelly_D
Shelly_D
