I bought my first TT in 1970, a Dual 1209. Used it about five years, then bought a Michell Transcriptor. Sold that one after five years too. I'd donate a molar to have either of them back.
Jack
Jack
Hej Peterh,Congratulations for a nice find, it seems to be a factory made one.
BUT
Leave the soldering tool for a while. You have already started to loosen the pots, be careful with them. The balance pot is
unique dont destroy it!. The volume pot might need replacement, i have suitable replacements located within EU
You EL84 is most likely shot, you need a matched quad EL84 in this amp.
And i repeat, you don't need to replace caps on the boards, you _might_ need to replace out-of-tolerance resistors but
i suggest you wait with this until you have a working amp that delivers full power.
As for the electrolytics , install EFB instead, there is ready made kits for this.
Victor,Hej Peterh,
many thanks for your advise, with some WD40 and carefully with pliers I managed to save the volume, balance and bass pots and all 3 are now in working condition, but I managed to destroy the treble pot (my bad), I normally like to have flat tone controls so I can live without treble pot.
I see you are placed in Gothenburg and that you have replacements for volume pot, just by coincidence are you related to tubular-well.se?
Would you suggest to first replace out of tolerance resistors and then later replace the EL84s?
cheers
Victor
Hej Peter,Victor,
I Am tubular-well.se
I recommend to start with EL84, and keep the soldering tool resting. Those boards are fragile and the design is tolerant against component variances. Better to keep calm and install new boards if and when you decide to keep the amp.
The EL84 is hard pressed and will need replacements, the ECC83 and 7199 is most likely ok.
( a persistent hum could be the first sign of a 7199 needing replacement, those are hard-to-find and expensive thus
it might be better to replace the boards to new ones that uses alternative to 7199 s.a. ecf80/ecf82)
I must ask : where did you find this treasure ?Hej Peter,
ok jag förstår, jag sitter själv i Lund
since I found the amp I spotted the JJs EL84 at your website, I will wait to save the money and grab them, probably the volume pot as well.
I will keep the amp and eventually replace the boards, etc. but I see it as a long term project.
many thanks for your advises
thanks gadget73, I salvaged the pots with little WD-40 and carefully turning with pliersI've had some luck holding a soldering iron to the threaded bushing on pots that were stuck and oil didn't free up. Some heat seems to help pull the oil in and free it up. Kind of a last-ditch effort but if its not working already there isn't much to lose.
I found it in the garbage room at the housing coopI must ask : where did you find this treasure ?
As it works it represents SEK 2000-3000 . Congrats !I found it in the garbage room at the housing coop
I elevate the AC filaments in all new builds now as a matter of routine. None so far have required any additional measures for hum control.I have found quite a few 7199's that have a bit of hum. What I have found, that has always worked, was to lift the filament voltage above ground by 25-50v. I do this by creating a 25-50v supply line. I make a 1-10 voltage divider from the high voltage power supply, and I find it necessary to bypass that with a small film cap, otherwise it has a high pitched buzz. This has cured every 7199 I have tried it on.
