Hi guys i am back. I took some voltage readings of the following transistors on board PC 36 and here they are.
LEFT CHANNEL: (A)
Q101 Q102 Q103 Q104 Q105 Q106
E +0.889 vdc E +0.889 vdc E +28.19 vdc E -40.58 vdc E +1.146 vdc E readings not able to take.
C - 39.93 vdc C -40.49 vdc C +4.110 vdc C -1.229 vdc C - 0.669 vdc C
B + 0312 vdc D +0.298 vdc B +27.49 vdc B - 39.97 vdc B +0.538 vdc B
Q107 Q108 Q109 Q110
E +0.002 vdc E -0.073 vdc E +0.536 vdc E -0.667 vdc
C +1.057 vdc C -1.057 vdc C +42.53 vdc C -42.40 vdc
B + 0.037 vdc B - 0.076 vdc B +1.060 vdc B -0.674 vdc
RIGHT CHANNEL: (B)
E +0.999 vdc E +1.001 vdc E +26.73 vdc E -39.82 vdc E +0.772 vdc E -1.583 vdc
C +0.002 vdc C - 39.97 vdc C +7.11 vdc C -1.583 vdc C -1.000 vdc C+0.756 vdc
B +0.417 vdc B + 0.420 vdc B + 26.00 vdc B - 39.27 vdc B +0.206 vdc B -0.994 vdc
Q107 Q108 Q109 Q110
E -0.397 vdc E -0.394 vdc E +0.200 vdc E -1.018 vdc
C +0.662 vdc C -1.481 vdc C +42.40 vdc C - 42.72 vdc
B -0.336 vdc B -0.449 vdc B +0.712 vdc B -1.565 vdc
And these were the voltages on the PC 37 board.
Holes: these should all be positive VAC
#1 +33.73 vac
#2 +33.53 vac
#20 +33.82 vac
#5 +44.03 vac
#6 +43.93 vac
#21 +44.07 vac
These below should be all positive VDC,
#8 +43.20 vdc
#9 -42.94 vdc
#19 -42.65 vdc
These should all be negative VDC
#7 -42.94 vdc
#10 -42.89 vdc
#18 -42.82 vdc
And on the numbered terminals from 1thru 26 on PC 36 board these are the readings a have:
#1, 0.00 ground. #2, +42.2 vdc #3, +42.2vdc, #4, -1.063 vdc, #5, +1.063 vdc, #6, +1.031 vdc, #7, +1.067 vdc, #8, -1.102 vdc
#9,+0.544 vdc, #10, -43.4vdc, #11, -43.4vdc. #12. 0.00vdc, #13, 0.00vdc, #14, 0.00vdc, #15, +.404vdc, #16,-43.3vdc,
#17, -43.3vdc, #18, +.216vdc, #19, -.440vdc, #20,-1.010vdc, #21, -.323vdc, #22, -.383vdc, #23, -.381vdc, #24, +43.2vdc,
#25, +43.2vdc #26, 0.00 ground.
The transistor that i thought was bad was in good shape I have just not soldered properly and had popped out of the mounting holes on two of the leads so i tested it and was good and i re installed it.
I think i might still have a short because the bulb on the dim bulb tester does not go completely out.
I noticed that the right channel upper output transistor is warmer at 104f than the left channel upper transistor at 99f and i can feel the "heat shield fins" are warmer on the right channel. So maybe the short is causing the heat on the output transistors? not sure? What should i be checking? Also some of the voltages are negative when they should be positive on the PC37 board?
