There is no point in using 6L6 type tubes instead of EL34 but there is a solid ground to use a GZ34 instead of 5V4.
Why not the 6l6? It sounds good to me.
The amp is pretty much fully rebuilt. Just original chassis and output transformers.If you are going to a 5AR4/GZ4 rectifier --- check the age of those electrolytic caps in the power supply. Especially the one in the first stage. Maybe worth it to replace them (or the can).
More distortion ( i have measured) as the transformers are optimized for EL34. And why settle with less optimal tubes ?Why not the 6l6? It sounds good to me.
this is what the load line looks like for a 5881 at 430 volts and 40ma into a 4.3k UL transformer with 43% taps. that should be what its working into. The solid line is what the tube's conductance swing looks like, the area under the dotted line would be considered the safe operating area for the tube. You can see it spends most of its time outside of that zone. Red dot is the idle current at 40ma.
If you connect an 8 ohm speaker to the 4 ohm tap, that becomes effectively an 8.6k load. This is what that looks like
looks a lot better. Its easier on the power supply too. On paper it says into a 4.3k load it'll make 57 watts, into 8.6k it says 35. Realistically its not going to do that because the power supply won't let it, but the current required to try and make 57 is a lot more than 35.
just for comparison, this is what an EL34 idling at 50ma into the 4.3k load looks like
that claims 36.4 watts, and given measured performance of an ST70 thats pretty darn close once you account for transformer losses and power supply sag and all that.
Yes. It increases. EL34 is optimal in ST70Peterh, do you know or have any guess how kt77 or 6CA7's would do distortion wise compared to a EL34 in a ST70? Thanks.
Inran KT-77's in my VTA ST-70 for around 10 years. They sounded good. I didn't hear any distortion. I picked them originally when I bought the amp kit after a discussion with Kegger. Now I'm using EH 6CA7's and really like them.Peterh, do you know or have any guess how kt77 or 6CA7's would do distortion wise compared to a EL34 in a ST70? Thanks.
At one point I used a set of KT-88's in that amp. They didn't sound right.I've had both the Gold Lion and JJ kT77’s as well as the EH 6ca7. They all had what I found to be enjoyable qualities but I haven't really had a normal EL34 installed in many years.
I'm not a fan of most KT-88s. I'm unsure if the amp setups were not ideal, but I've heard many KT-88s amps lack that "tube magic." Maybe it is their midrange resolution (or lack thereof).At one point I used a set of KT-88's in that amp. They didn't sound right.
The top end and bass was ok, but the midrange didn't sound right to me.
But using those same tubes in an amp designed to use them they sound great. I thought the KT-77's had a well balanced sound from top to bottom.
Nothing exaggerated. But I do prefer the EH 6CA7's though. The low end is a little beefier but we'll controlled. Since I don't have tone controls in my mane system they worked out well.
That's what I found using them in my ST-70. But they sound great in my PPP mono blocks. I would like to try some 6550's, but having to buy four for each mono block is expensive. I already had the one quad of KT-88's that I had tried in my ST-70, so buying another quad was the cheaper route.I'm not a fan of most KT-88s. I'm unsure if the amp setups were not ideal, but I've heard many KT-88s amps lack that "tube magic." Maybe it is their midrange resolution (or lack thereof).![]()
6550s are my favorites. Those black plate TungSols (USA).That's what I found using them in my ST-70. But they sound great in my PPP mono blocks. I would like to try some 6550's, but having to buy four for each mono block is expensive. I already had the one quad of KT-88's that I had tried in my ST-70, so buying another quad was the cheaper route.
At around $560 for new issue, and even more for NOS to retube those PPP mono blocks, I'm good right now.6550s are my favorites. Those black plate TungSols (USA).![]()
