Robert:
Try something simple before replacing the driver board. Install a capacitor between the input jacks and the imput of the first tube. Then listen and decide. The cap should be between .05 microFarads and .1 microFarads.. It's cheap and it really does great things for the sound of the amp. I know it doesn't do anything about the feedback, power supply or anything else, but if you feel you are ready for the challange of installing a new board (with additional parts) then the capacitor shouldn't prove too much or a challange, its cheap ($1-$2 per channel depending upon where you source the caps from) and maybe you'll like what you hear. IF you don't you can always go on to the new board and get those improvements.
The reason I sugest this is I'm one of those people that think feedback can be a good thing when properly implimeted. I realize that is a sore point these days, but consider this, the Stereo 70 has a reputation for not delivering "tight" bass. One of the benifits that feedback does do is lower the output impedence of a circuit. In this case that would improve the damping factor for the amp. For those who are not familiar with damping factor, it is one way the amp controls unwanted excursions of the speaker. Generally, the higher the damping factor the better the control. (Every mod has some kind of trade off, the trick is to find one you like). Lowering the ouput impedance will increase (improve) the damping factor.
The biggest reason to try it is it's cheap:thmbsp:, easy to do, easy to undo if you don't like it, and (in my opinion) has results far beyond the cost and effort involved) why not try it.
Whatever you try - good luck to you and happy tinkering.
Shelly_D
Shelly,
I don't really agree with you ..
Putting caps on the input does restrict the frequency range that the amp has to work in. But by doing that you are not helping the REAL problem which is a mediocre design for the original driver board with the 7199 tubes.
... If you compare an ORIGINAL Dynaco ST-70 with a modern tube amp like a Rogue, Audio Research, Conrad Johnson etc. these weaknesses in the sound from the original ST-70 are very noticeable.
When people hear an original ST-70 for the first time they go "Ahhhh - that's a nice smooth sounding amp" - Yes it is nice sounding but again - It's not accurate. But their ears are so attuned to their hard sounding Pioneer, Kenwood etc. solid state receiver that they "think" they have reached audio nirvana with a stock 70.
As I said above if you really want to hear the 70 at it's best - beef up the power supply with the SDS under chassis cap board (this has already been done on your amp) or pull the old quad cap and install the 80, 40, 30, 20 cap AND get a driver board upgrade - either the Curcio, Diytube, Triode Electronics or VTA driver boards will be a huge sonic upgrade for any original Dynaco ST-70.
If you are doing a complete rebuild then I would also pull the power transformer and replace that with upgraded PA-060 from Triode or Dynakitparts. The transformer on my Latino Dynaco ST-70 kit amp runs so much cooler than the transformer on the old original amp - you can put your hand on it and hold it on there even after hours of continuous play. It's warm but not "hot" like the original Dynaco ST-70 amp I have.
Putting caps on the input as you suggest is like putting a band-aid on the finger of a person who has a much more serious internal problem. No real help IMHO.
Charlie
Shelly,
I added a .05 Mfd cap between the input jacks and the driver board on my old stocker. I listened to my stock amp for a couple of hours with music I am familiar with. I have to say there is *maybe* a VERY subtle difference in sound quality for the good - BUT IMHO this is a mod that is akin to putting a higher quality air cleaner on a stock car and getting maybe TWO more horsepower. You can't turn a STOCK Dynaco ST-70 into a world beater with this input cap mod. The mod does not "*dramatically* improve the sound of your stocker" as you said. The difference is subtle. The stock Dynaco ST-70 amp needs a modern all triode driver board and a better power supply to really address the demands of todays digital music sources that have a high dynamic range. Of course if you listen at low volume levels and not at realistic sound levels you *may* be satisfied with the input mod as you suggest.
After listening to the input capped stock ST-70 for a couple of hours I cycled in my Bob Latino upgraded ST-70 amp with the VTA driver board and upgraded power transformer that I built from one of his kits. I then listened to the SAME music with SAME components. The bass is tighter and goes deeper on the new amp. The top end has much more extension and the new amp has much greater resolution. This amp sounds more tonally accurate than the stock amp. There is no real comparison between the stock amp and the new amp. I have an audiophile friend who has listened to my new amp and has told me that my new ST-70 kit amp sounds every bit as good as the Rogue 88 that he bought new and which cost him about DOUBLE the cost of my amp kit. I think he paid like $1300-$1400 for his Rogue.
IMHO the input cap mod is a mod whose overall affect is subtle and a mod that cannot turn a Dynaco ST-70 stock amp into an amp capable of dealing with the dynamic ranges found todays digital music sources.
Charlie
"I guess we will have to agree to disagree."
Agreed, couldn't have said it better myself.
Everyone hears different and looks for different things in there system, not all
will ever agree what is right and what is wrong.
Firstly, do you have any drawings or pics of your plug-in filters that are convenient to upload? Secondly, have you yet incorporated a filter in the rebuild you intended to do. Can you list the parts and their values. Or is it simply a .1uF cap in series?I have a stereo 70 which I had been running with bandwidth limiters set to 12 Hz and 22KHz and it sounded absolutely glorious. — SNIP— In the rebuild I intend to add an input cap to the circuit forming a high pass filter - still a form of bandwidth limiting. If you ever have the opportunity to listen to a stock stereo 70 vs. one with the filters you will hear the difference. In my case I built the filters outboard and plugged them into the inputs and then the preamp into the filters.
GEEE, interesting how NOW magically those crappy output transformers HAVE the Wider Bandwidth..
(his original bandwidth mod probably helps original circuits, but it ain't "because of transformer" bandwidth)
