shelly_d
Not An Audiophool
It strikes me that some information collected in one place could be useful here. If I am offending by posting this, please forgive me, I only intend to help.
The 55 volt output is used to obtain 32 volts on the "grid" (pin 5) of the output tubes. A change of the bias resistors will correct the voltage for the 60 volt output.
Since you have no transformers you should be aware that the EL34 is capable of more then 35 watts output in push pull. Dynaco used a power supply that did not respond well to very rapid demands in current draw. (That kept the price down) To compensate they biased the outputs to run class A. That kept the current draw in the output tubes nearly constant. You have the chance to build a more robust power supply that could respond to current changes quickly and therefore change the bias of the outputs to operate in class AB, getting more power out of them.
As to the output transformers. They are very different from power transformers. Power trannys operate at only one frequency, 60 hz. Output transformers must operate over the entire range of human hearing, considered to be 20 Hz to 20,000 Hz. The winding for that is very different from a power transformer. It is important to actually use an audio output transformer in this application. As mentioned earlier there are a number or options out there. The Dynaclone's are suposed to be made to the original specs of the Dynaco Transformers. If true (I have no reason to doubt it I just never used one) then they are excellent for this purpose. Also the Edcor output transformers are very well thought of here on this board as well.
You will need to set up a power supply filter (can cap and choke in the original ST70) Those circuit pulls usually don't include those parts. A resistor could be substituted for the choke and work almost as well (sorry I don't know a value for that) but you will need caps capable of very high voltages. You may need to use caps paired up and wired in series along with high value bypass resistors across each of them to guarantee the voltage across each is kept within limits. (Example, a pair of 80 microFarad caps in series, and a 300K to 500K ohm resistor wired across the leads of each cap. Use photo strobe caps rated at 450 vDC. The network will be rated at 900 vDC and 40 microFarads).
Good luck with this and please let us know what you did and how it worked.
Shelly_D
Shelly_D
