David_NC
I finally finished 'restoring' my ST-70 last night. I replaced all the caps, most resistors, and the selenium rectifier. All that's left is to replace the rusty hardware (aka screws) on the chassis, which I'll do tonight. This is leading up to the scary part - powering it on for the first time, setting bias, and making sure it works properly. It was suggested that I buy a cheap set of tubes for this part, since mine has the original Dynaco and Tung Sol tubes in it. I see Electro-Harmonix and JJ are about the cheapest brand name EL34's that I can find. Are there any others I should be considering? I have 7199's and will use 6U8A on an adapter at first. I don't think I missed anything that's needed to get this back into shape.
Here are some pics of it from last night. I see I still need to remove my labels (AKA blue painter's tape), clean the chassis, and neaten it up in general a bit. I'll rewire the switch and fuse so that they are both on the hot line. I'm not sure sure I like having the neutral switched. Once it passes the preliminary tests, and I get some listening time in on it, I'll replace the stereo/mono switch with a volume pot and perhaps move the RCA jacks to the rear. Somebody replaced them in the past and drilled the front chassis, so it's not gonna look good there without doing something.
