I have upgraded one of my ST-70 with the Triode USA EF86 board. First mistake!
The Triode page says it comes with 20 page installation manual LIES! No manual with board and parts.
I now know I should have used the Tubes4hifi high gain 12AU7 board. There is tons of info and Bob
Latino gets involved personally with questions.
I have tried to contact Triode with no results. I received wrong value and also wattage resistors.
I have that corrected by buying my own parts. Also note that eyelets 8, 9 & 10 are unmarked, but I traced
the foil enough to see 8, 9 and 10 are all board grounds. So I have pin 9 to the ground lug near the quad cap,
Pin 8, 10 ohm ground isolation resistor to pin 3 front left takeoff socket (which is an open lug)
Pin 10, 10 ohm ground isolation resistor to pin 3 front right takeoff socket (also an open lug)
The rest of the parts I bought directly from Dynakit Parts which include
new 30/20/20/20 quad cap with new carbon comp 3 watt resistors VOLTAGES DEAD ON SPECS
new bias supply rebuild kit NEGATIVE BIAS VOLTAGE DEAD ON SPECS
on/off and stereo/mono switches
gold plated wider spaced 1/4 phono. input jacks with new metal film resistors
I installed a CL-90 current inrush limiter from Mouser
New choke that I opted not to use on this unit...saving it for my other. The stock one has no leakage and
ohms out fine. I bought double of everything to recap my working ST-70 with an old EF86 board,
Roy Mottram, I believe it has been identified as, from it's yellowish/green color. And it sounds great.
I did the yellow sheet mod with UL fast recovery diodes and bypassed the Selenium with a 1N4007.
HERE IS MY PROBLEM, as per Triodes ONLINE assy. instructions to use the 12AU7, you are supposed to
jumper the board J1 to J2, which I have done, and used eyelets 24 & 25 for filament voltage from the front
power takeoff sockets. I have filament voltage present on both EF86. However I believe (I put it on the back burner) with the associated problem and other projects, if memory serves me correctly, I have filament voltage
to the 12AU7 pins 4 and 5 but the tube heaters will not light the tube, because of what I believe to be missing
heater center tap at pin 9.
As stated above ALL voltages are correct, including bias, ALL tubes light EXCEPT the 12AU7 phase inverter,
and I have MANY 12AU7, all tested with my Sencore Continental II MU150.
I did see another post, with a similar problem, once while doing a search here on Audiokarma, but can't seem to find it again.
Any help with this would be greatly appreciated.
