klitzy13
I am hoping the brain trust can help me out on this one... I have a Stereo 120 that was previously worked on by someone other than myself. The output transistors and R16/R17 are replaced on the PC-14 left channel. The outputs were replaced by 2N3772's. Everything else in the unit appears to be stock. The unit was brought to me because it was still not getting any output on the left channel. I got it on the bench, did some initial checks to make sure nothing was blown again on the left channel, all looked good so I tested it and had output on both channels. I had the cover off and had it running (no load, just a scope hooked up to the speaker terminals to watch for the 1k signal I was inputing into the RCA's) and smelled the dreaded burning electronics smell. I powered the unit off and noticed that R16 on the left PC-14 was letting off a little smoke. Checking the resistor it didn't blow but is now reading about 260 ohms instead of 300 like R17.
I have checked all of the voltage test points in the instruction manual (powering the unit on for only a few seconds at a time, letting things dissapate then moving to the next) and all of the voltages are close and match the right PC-14 board. The only differences I can find between left and right are the voltages at Q1. I checked D1, D2 and D3 on the left PC-14 board and all test fine. The output transistors test fine as well.
I'm stumped as to what to look at next or where to go on this one. Any suggestions?
![20191103_150555[1].jpg 20191103_150555[1].jpg](/forums/data/attachments/1536/1536623-eda2df0b11230469806b3f6ca0985871.jpg?hash=7aLfCxEjBG)
![20191103_150638[1].jpg 20191103_150638[1].jpg](/forums/data/attachments/1536/1536619-1c211cfcadb9b855814645fcfa340098.jpg?hash=HCEc_K25uF)
![20191103_150627[1].jpg 20191103_150627[1].jpg](/forums/data/attachments/1536/1536621-e247703442b08b8388d6088c270f9f13.jpg?hash=4kdwNEKwi4)
