I have an early Dynaco ST-70. I rebuilt it with new caps, resistors, PCB board, filter cap, etc. All stock values. No mods. It all works great.
I'm considering getting a matched quad of KT77 tubes for the amp.
Each channel of the amp has different brands of tubes.
Original Mullard EL34s in the left.
Matched pair of Winged C EL34s in the right.
The other pair of mullard EL34s have sadly failed.
So I really have a two part question, I guess.
1. Is it a bad idea to have different brands of tubes for each channel? When set to mono, jumping back and forth between the channels, I can barely tell the difference. So they seem pretty well matched.
2. I find the overall sound to be a bit dark. The treble seems pretty rolled off to me. Its wonderful on older recordings, but sounds a too muffled on modern stuff.
I've read the KT77 tube is brighter than the EL34. Anyone have experience with these tubes? I'm considering getting a matched quad of these. But I'm not looking for a subtle bump in treble reach. I'm hoping for something more pronounced. Would the KT77 deliver more treble over the EL34s?
Thank you all for your input.
