TravAndAlex
Hi. I'm hoping you can help me. I have a Dynakit ST-35 kit that I've used daily for a couple years. I love it! Unfortunately, today I noticed that one channel has an occasional static noise (quiet popping sort of noise). I tried disconnecting the pre-amp and I swapped tubes left to right, one at a time, to see if I could pinpoint the issue. No change. Static still in that one channel. Swapping the speaker wires, and the popping followed the channel, so the issue is definitely with the amp. Wondering if you can help me troubleshoot or suggest where I should start? Thank you!
