Hi all,
Just acquired a nice engraved 2270 S/N 3024 and it has some issues. The problem is the output is equally distorted in both channels, low volume its somewhat clear but as you increase the volume it gets distorted, the more you increase the volume the more distorted it gets. I pulled the jumpers and tested the amps separate from the pre and both amps are crystal clear at all volumes, so the problem is in the preamp section. I cleaned and deoxed all the switches and pots but the problem remains.
So my question is where would I start looking for the distortion issue that is feeding both channels at the same time? P400? Any advice would be appreciated.
Second issue is FM doesn't work at all, all I get is hissing through the hole spectrum. AM works fine but as with the other modes it too is distorted. I can deal with the FM issue another time, for now I just want to get the distortion issue solved. I would have used the search engine to find other threads on this issue if it was working. Thanks for any help.
