swamppirate
Lunatic Member
Dang this thread reads like War and Peace! Thanks for everyone's input, I have learned a ton!
Early 70's watts vs. 80's watts
I have a Sansui 5500 ( built around 1972) that is rated at 45 watts. When compared to 80's and 90's gear, the 5500 sounds more like 100 watts per channel. Were receivers in this timeframe rated differently, with different standards?
...I believe the ratings are the same for the purposes of FTC. However I think the testing procedure has been relaxed. They now use a shorter duty cycle, 1/6 perhaps vs 1/3 back then...
...One is the available current from the amp. Some (not all) newer amps and AVR's actually restrict current when the load dips to 4 ohms reducing the power it would have without current limitation...
Also there is peak power vs FTC ratings. Harmon Kardon and NAD, Perhaps others build some of their amps with 6 db's of headroom, while the average amp often has 1-2 db's headroom. This however should be taken with a grain of salt since IHF dynamic headroom is measured over just 10-20 ms. Still, we might get an extra 2-3 db's more power for music for longer periods from these rare amps.
NAD and Proton, Pioneer at one stage, Hitachi in the 1970s, Kenwood etc all built commutating rail amplifiers to allow for high short term power and keep the dissipation under control by running lower rails the rest of the time when transients didn't demand it. Many of those amplifiers were adorned with a rear-panel impedance switch. This tell tale switch either activates lower psu rails or adjusts the trip point for low impedance speakers. On modern AVRs, the rear panel switch usually selects a lower secondary HV rail to pro actively prevent excess dissipation and premature failure. I see those switches as 'cop-out' switches- excuses for poor design.
Far as FTC amp rule, I believe 1/8 power preconditioning is now the standard.
With regard to the impedance switch, Audioholics did a story or two on that some time back. Their conclusion is that in many cases the switch is there to allow the amp to pass some temperature requirements of UL rating tests. Based on their testing though, they suggest to run the switch at the highest impedance setting despite the speaker load. They found the voltage and or current limiting imposed by the circuit actually is likely to contribute to more clipping and nastyness as people try to push them with the self-imposed restriction turned on.
In my opinion, the vast majority of today's buying public have no idea about what a watt is, and RMS probably means even less.
I think that except for some quality high-end gear made today, nothing compares with the mass market stereo gear that was available in the late 1970s.
I use vintage gear, but I'm always wondering when some old component will reach the end of its useful life, and I'll have to get stuff fixed. If new gear was available at a price I could afford, I would seriously consider switching, providing the new gear had the quality of my old gear.
70s watts sounded better!
You may be on to something there... Seriously though, all of my 70's era SS gear is far better sounding than the "lighter" cheaply made stuff (aka, BPC) that was made in later decades.
Do you consider that a realistic comparison? If I race a stock Corvette against a stock Chevette, should I be surprised when the Corvette wins?
