I am posting this, as maybe it may be on the mind of some other AK'ers, also.
If you can, I would appreciate a detailed explanation of how a magnetic field amplifier operates. I THINK I understand it, (I have figured out things on my own, most people I talk to do not know, or care, how those amps work).
From what I have surmised:: A basic , direct-coupled amplifier, with more transistors, than the sink size in the amp would normally dictate, is used in these carver amps. The "magic", (if that is the word for it), seems to be the power supply. Small caps, that are MUCH too small for the rails(in a normal amp, anyhow), and a "transformer", that is connected, through a triac, to the power line. The transformer has an impedance MUCH too low to operate directly from the line, and so, it is just "barely " on, when there is no, or a low, signal. This is accomplished, by sensing how hard the amp is being driven, and then, modulating the power transformer drive, by that same amount. The b+ and b- rails are very low, just enough to turn on the output stage, until a demand is given, Then, the rails are increased, up and down, as the load varies. By doing this, the dissipated heat in the amp and tranny is low, or so it is claimed.
Is this right, and if so, isn't this pretty much the same as a "class H", amp? And, why the name "magnetic field amp"? There are no magnetic devices(like chokes or transformers )in the actual amp sections after all, just a specially driven "transformer", (in some ways, the power supply is more like a switcher, but it operates at much lower frequencies, than most switchers I have worked with.)
I also have a real feeling, that while this will work with music, the whole power supply, and amp, would probably "melt down", with a true sine wave tone, of say, 100hz., after a couple of minutes.
